Help USB connection not recognized as such
RedLester
I want to load the photos from my T-Mobile (ZTE) Concord phone's SD card onto my PC using the USB connection.
But when I connect the phone to the pC using the USB cable, there is no notifcication on the phone "USB connected", and on the PC side Windows Explorer does not see the USB connection.
I brought the phone and my problem to a T-Mobile store and the sales/service rep went to the Settings/Application Settings menu on my phone and turned on "Unknown sources" (allow installation of non-Market applications) and he assured me that would resolve my USB problem.
It did not.
I've tried with SD mounted and umounted, neither setting works.
Still when I connect the phone to the PC with the USB, all it does is start charging the phone battery, still no USB connection taking place.
Please help.
Thanks.
Welcome to the forum RedLester :ciao:
"Unknown sources" has nothing to do with the usb working. Or not that I know. Thats for installing apps from places like Amazon. Do you have an option in settings for usb debugging? If so, check that box. Do you have drivers installed for the phone? I tried looking for oms but can't see anything.
Thanks for your reply Atma. (and for the welcome).
I finally got my photo upload working. I had been using a USB device I bought, ignoring the statement "you must use the USB that came with your phone". Then (while searching though a dresser drawer for something else), I found the USB that came with the phone. As soon as I used that USB cable, my problem went away.
God bless you and yours.
Les
