USB connection to computer: not mounting
GTbrewer
I just got my Acer Iconia A500 earlier today, and am now trying to transfer
files that I already backed up from my old tablet (which is about to be wiped
and sent in for warranty repair). When I connect my tablet's microUSB to
the computer's USB, the computer (winxp) wants to see it as a new device, not
external storage (i.e., it doesn't assign a drive letter). The A500 is not giving
me any help, either.....
On my Motorola 520, I get a notice in the notifications area, and can select
the type of USB connection; in my other tablet (Archos A101 IT), it asks if
I want to mount it for copying files between it and my computer. The A500
is silent, except for something called PC Sync, or something like that. It says to go
to www dot acer dot com and find the program, but if it's there, it's well hidden....
All I want is to be able to copy all of these files from my computer to my new
A500, both now, and in the future.
Suggestions?
Thanks,
--jim
It looks like the tablet is switched to adb mode, which allows control from PC, but don't mount the drive. You can check Setings / Applications / Development and untick "USB debuging". If you leave this on and tick "USB debugging notify" also, tablet will connect in ADB mode but will give you the option to switch to USB mode (massstorage disk access) from tray.
I just tested that (after the last of three OTA updates, now up to 3.2).
Under Applications-->Development, I don't have a "USB debugging notify". I unticked
USB debugging, and connected the USB cable. I get the same "Acer Sync" message,
saying turn on Acer Sync so you can transfer files between your tablet and your
computer (or something to that effect). Before that, no drive was created on the
computer (but it DID register as Acer Iconia Tab A500). I selected Acer Sync
again, and it turned USB debugging back on...still didn't mount the tablet as a
drive...BUT, I do now at least have a device listed instead of a drive now, where I
did not last night.
So, I can copy files back and forth, but ONLY by using Windows Explorer (or in my
case, xplorerr2, which has the option for split panels, bookmarks, more controls,
etc.), but I can't move files from a shell (Cygwin + zsh).
Is there a way to take that one step further, and get a drive letter, to allow use
via a zsh prompt? Or is that a M$ issue?
Btw, last night I did get everything transferred, but did so using FTP.
Thanks,
--jim
PS: First impressions: this beastie is a screamer! Talk about FAST! My Motorola
Bravo (MB520) is sulking in shame...and I thought IT was fast. :-) I also noted
that, while doing 32 updates from the Market last night, it did them in parallel,
where my MB520 does them one at a time. Nice.... And it did them a LOT
faster, too.
OK, everything clear. This Sync program uses adb and can also mount the drive. To mount the memory as drive you need Windows driver for the device, looks like the USB mass storage driver for your tablet is not installed.
First try to download the bundle from Acer website and install it , it should install or update the drivers. Connect the tablet with USB debugging disabled and Windows should ask for the drivers. If this doesn't help, try to update the drivers manually (go to Windows hardware manager, look for the device and try to find the driver from downloaded archive - don't know ho to do it exactly, it's different in every system version and I have just Linux). Then USB mass storage should also work.
Acer Support: Downloads & Support Documents - Tablet / ICONIA TAB / A500
PS: Good for you, my ZTE Blade can download just about 3 parallel updates.
