Help USB Connection Tone
crboone
Is there a way to change the default USB connection "tone"? Mine sounds like a loud phone ring that I don't like. I've looked at all of the settings and I can't find anything. The default notification is *not* set to that ring, so it must be set somewhere else. Unless it just can't be changed(?).
Does no one know how to change this, or does anyone else have this "phone ring" for the USB connection? I found that my calendar reminders are using the same ringtone, but it's not set anywhere that I can see (and it's not my default notification ringtone).
EDIT: Never mind, I found the notification buried within the stock calendar app. Not sure why that affected the USB connection, but now there's no phone ring tone after changing the calendar app to what I wanted. The USB connection is silent now. A little odd, but it works.
