Hello everyone.
I really hope someone will be able to help me to fix this, have been scratching my head for some time and googled for hours without any success.
So the issue is that when I connect my phone to the pc it does not recognize it, it worked like maybe 2 weeks ago or possible more, not used it since then. It seems like it is charging but when I plugged it off after few min it seems it did not charge at all, connecting it via normal power outlet works charging fine. Anyway this is not main concern.
I get no notification about that I want to mount it to pc nothing appears simply.
I tried a different cable, tried different pc. Tried restarting, tried factory reseting, but no luck so far. I do not have usb debugging on. I also tried to toggle the ask me usb thingie and setting directly to disk drive also did not work.
I am really out of ideas what to do, will I have to go back to store and replace it?
Please help=/
Best regards
Evilus
Please help=/
Best regards
Evilus
