Help USB Debug Issues
ghamden
If you are having usb issues charging, not connecting to pc etc.
Check to make sure Debug is unchecked then reboot see if you problem went away most likely it has
if not then you have other issues.
Mine would not charge from wallcharger i unchecked debug rebooted and charging normal now
