Help USB debugging mode going berserk!
mrbigv770
After doing the PRL update. I dialed *983*87274# and selected AT...now my phone stays in debugging mode even when it not plugged in. I unchecked it, rebooted and turned it back on. Now it doesn't work. Any ideas?
Are you sure you choose AT? Mine does that if I choose All functions.
I did select AT... the notification would not turn off. Even when I unchecked the box it still stays on.
Have you tried to disable it going through the notification status bar with the phone plugged into the computer. Click on the notification and it will drop you on the debugging screen. Same screen but maybe it will work. Also you might want to check and make sure you still have the drivers loaded on that computer.
ok I'm good now...I hooked it up to my lappy when I got home and er'thing is fine. WHEW!
I think it was my stupid work computer.
