Root USB drivers not working after joey custon kernel
D
Deleted User
Guest
I have a rooted and joey custom kernel flashed moment. The USB drivers were ok until i put the custom kernel on, after which my phone is no longer recognized by my computer...did i do something wrong, and how do i fix? thanks in advance
When you flash joeys custom kernel, it turns on USB debugging in menu/applications/development. Uncheck this to enable access to your sd card.
You can also download the USB drivers for PDANet, which work with usb debugging turned on. This way, it doesn't matter if you have debugging or not, you'll have a valid driver.
