Help USB error code 43
Scorpin
i tried in many different computers and i take the same error... unknown devise.. error code 43 please help........ thanks anyway!!
connect the phone to another USB port. there are always multiple USB ports available on the case or the laptop.
check out your phone's output port, there is a flat thingy there, it has to be in the center. if its not, you need to take it back to its place with a knife or something.
have you checked the other thing I told you?
also I read this on google help:
I had the same problem as well and I was doing continuous back flips and bursting out with anger and so forth! What I did to fix this problem is that I turned off my phone while plugged in the computer than turned it on while holding the upper volume button which lead me to the what-so-ever screen called where you see some options. This is where I heard the PC make the noise when a device is connected to it. After that I unplugged the USB cable and the disconnection sound happened. That is when I realised that it will work the next time I turn on my phone and boot it normally.
for more info check out this link: http://www.google.com/support/forum/p/Google+Mobile/thread?tid=4dedeb14b7ccb58e&hl=en
