Help USB failure while updating to FROYO !!
YINE
and there's only yellow android symbol with 'downloading ...' quote and says do not turn it off...
While i was updating it to FROYO on KIES, PC showed USB failure on the device and stayed up like that ...
what should i do ??? btw phone is from Bell
You should go onto bells vibrant forum's and see if people there are having the same issue or if there might be a way to fix it with people like you with this issue.
I'm not sure if this will work for a Bell Vibrant, but if you boot into recovery, under re-install packages, there are two other options there. I believe they are clear data, and clear cache. Wipe them both, and reboot. This solved problems for me awhile back over a similar issue.
