After unplugging my phone from usb charge, the usb icon in notification bar never goes away? When I pull the bar down it says usb connected when it clearly is not. Not sure why this is happening.
Wish I could help. I had the same problem with mine a few weeks ago. I was having a bunch of different problems at the time. I ended up doing a factory reset and starting over and haven't see that problem since. I suspect that a program or a combo of programs was causing the problems. I would start by removing the last few apps that your installed and see if that takes care of it.
Since I did a factory reset I've found that LauncherPro caused a lot of problems. I've probably installed and removed it 4 times in the last few weeks. It seems to work fine for a few days and then I get lockups, force closes and bad lagging.
