I'm trying to flash my phone back to stock so I can root to a different rom, however when I plug my phone in it just charges. When I try to use the updater to flash the phone the usb doesn't recognize it justs says disconnected at the bottom. How can I fix this?
Sometimes you just have to reboot the pc or plug things in the right order. There is also a usb debugging setting somewhere in the settings menu that needs to be turned off
