Help USB jack unusually small?
StevenZ
Member
Just got my HTC One last night, and noticed several of my USB cables' plugs are a bit too big for the phone's USB jack. These are cables I'd previously used without issue on my Samsung GS3 and even my HTC Droid Incredible back in the day.
It's not the outer case so much as the inner connector that's too tight for the plugs. And it doesn't look like a connector-to-case-alignment issue.
The supplied HTC USB cable is less of a problem, though still a bit of a fight. I'm just not excited about the next two years of fighting to plug the phone in. :(
Mine is a little tight as well, never gave it a second thought.
I don't believe anything is wrong, but I can't tell without actually checking it first hand. If you're worried, take it in to a Verizon repair shop and have it looked at. Make sure you take the other cables with you to show the tech.
