1. Is it normal to have to power off/on to get the what appears to be the SD card to show up in Windows File Explorer?
2. Is bluetooth the right folder to put sound files in from the PC in order to use them as Notification sounds?
thanx
EDIT: well, bluetooth is not the right folder. I ask because on Moto's website it says to get a sound file for notifications onto the droid from the PC, use USB mass storage and
thanx
- Follow this file path to paste the music file you wish to copy over as your message notification ringtone: MEDIA>audio>notifications
- Paste file you want as a ringtone into notifications folder.
