Help USB mass storage
DMajor239
Android Expert
The usb mass storage is not working. When i connect the usb cable between the phone and the pc it shows that it is charging, but the pc does not find the drive. Its very awkward because just yesterday it was working fine.
Check the settings on your phone. When you connect it to the computer you're settings might be set to charging
change by going to wireless & networks/usb connection and set it to "ask on connection"
If not johnny might be right. It might be your cable, or the usb port on your computer.
ahh thank you. :cool:
