USB OTG for US Note?
vice86
Just saw a video about the Galaxy S3 and USB OTG allowing for BT keyboards and console controls to play games. So i YouTubed and saw you can do the same for the Note.
Where do you get a USB OTG cable for the US version of the Note? Was on Amazon but a lot of 1 star reviews saying it doesn't work on phones and that it may just be for international versions.
Any suggestions?
Any suggestions?
I ordered this cable (actually two cables). Zuweiyu(tm) Micro-b USB Host OTG Cable and Mini USB Host Cable (Otg Cable):Amazon:Computers & Accessories
So far I have only used it with a thumb drive but it works fine. I am running an ICS ROM so I can't say for sure if it works on the stock GB setup.
I'm running the U.S. version also (i717). I had ordered an OTG cable for my GSII and never got it to work. When I got my Note, I tried the same cable on it and didn't get anything. So I bought another cable (the one I linked to) and BAM! as soon as I plugged it in the phone recognized the cable. If you try a USB thumb drive with it, use a file explorer to go to /sdcard /usbstorage You should find your thumb drive there.
