I really couldn't tell you... I think the only way to really test it would be to get am adapter and see if anything will connect... I kind of doubt it tho... Although maybe in ics we could get it to work as it will have official support for external peripherals although that may be tablet specific they're may be a better cahnce to get it working...
I would just get an otg adapter... Which is basically just a female usb connected to a male micro B cable... I would try ebay or whatever else you are comfortable with... Then plug it into the phone and plug in a keyboard or something... Although I highly doubt that it will work...
Also ICS shouldn't be too far away maybe a month or so... Hopefully... And on the Ideos X6 forum I was reading about the same thing... them wanting otg... And it probably could be possible to re-code the kernel to enable it... I have no C or C++ programming skills... The only programming I know is TI-Basic :/
