Hi,
I am having some problems with my new Xperia Play.
Basically, when I connect the phone in Media Transfer Mode the Memory Card shows up as blank in Windows.
I can create a folder or transfer a file to it 'blind' but this then dissapears.
It was working fine, but then this happened.
If I connect is mass storage mode or take the memory card out and use it in PC it works fine, everything is there. The memory card works fine in the phone also in terms of the data on it.
Just the 'media transfer mode' that is acting strange. The phone shows up in windows, as does the memory card, but blank!
Windows 7.
Any ideas?
Thanks!
Windows 7.
Any ideas?
Thanks!
