Root USB Stoarge
mrw5641
Member
Hey all, has anyone had a problem connecting to the CPU after root, i.e. I want to put a new rom onto my SD card but I can't seem to get it to show up? Any ideas?
Thanks
I tried searching for it, I was unable to find it. I was able to use Rom Manager, but I still an unable to get that option. I was using Pool Party, now I am using AOSP rom, but I haven't checked that option yet.
Which AOSP ROM are you running?
I've tried three different ROMs. They all have a "Enable USB storage" option in the pulldown notification bar when you connect your phone to the USB port. Select this and let us know if it connects to the USB.
Yes, will do. I am working now so I won't be able to try until later. I have yet to try it since I recently updated from TSM Pool Party. Which rom are you using no Valorian
