What is USB storage?
Why is SD card at zero?
Dear Lunatic59 and Slug,
Thanks for your confusion/explanation...
1) So System Storage is where all the android application files are kept?
2) USB storage is a partition of the internal hard drive where the user can keep his files. This is listed in the file directory as mnt/SDcard. Is this correct?
3) So I don't have an external SD card? I assumed that my Samsung Galaxy S2 shipped with one in! :-(
Where are my Apps and associated data stored?
Thanks again
On a similar issue, I've got a Galaxy S2 with an SD card installed. I use Go Launcher Ex.
When I upload MP3s from my Windows PC they get stored into USB storage and not the SD card. My USB storage is running low. Can I move MP3s from USB to SD and can I set it so things are automatically uploaded to SD?
Thanks in hope
Steve
Thanks in hope
Steve
It doesn't allow me to drag and drop from Internal to External folders.Once you mount your phone as storage, as chanchan05 stated, you should see two removable drives pop up. One will be your internal storage partition and the other will be your SD card. You can easily drag and drop between them, but if you have any playlists set it will break them.
but the storage says it has 9.53GB/11.50GB used. how can i retrieve the files?
I also have the same issue although it is unclear to me if the mount point has just been moved.Hi.. i recently updated my galaxy s2 with the new ice cream sandwich - Nova1.0.1beta 1.. however, when i got my fone back, sdcard/usbStorage is empty.but the storage says it has 9.53GB/11.50GB used. how can i retrieve the files?
cannot save new files to the usb storage either...
how can this be solved?
help...![]()
Very useful info so many thanks for this explanation, but I still dont quite see the link between the quotes machine specs and actual storage.Let me add just a little more technicalconfusionexplanation ...
Android has, for apps, two general locations. Internal and external...
