is there anything better than pdanet or easytether? I cant seem to get pdanet to stop crashing after running a few min. and easytether just doesn't seem to work
Easy tether worked great for me but if you really want to tether just root your phone and then you can use it to Wifi or usb tether. Question did you poad the drivers onto your computer to use Easy tether because it worked without any issues for me. Also have you taken the updates cause if so that could be blocking you from being able to tether. Not sure on the last update but i know the first initial update killed tethering from the devices already loaded apps.
