Help USB Tethering not working in 4G/3G after update
Scooterman1
Member
Updated the phone. The tethering used to work on 3G, and 4G. It only works on WiFi now.
When I connect a USB cable from my Notebook, it disconnects from 4G, or 3G (whichever mode that I have it on), immediately tries to reconnect, but gets this error:
Data Call Failure
Error Code 67.Registration failure. Your PCS Vision username and/or password may be incorrect. Please try again.
This is with the HTC USB default tethering. It's the same result with Easy Tether.
Is anyone else having this problem? If not, does anyone know what may be causing this? I have Reset the phone to Factory Default with the same result.
looks like sprint locked it down. you can use easy tehter (i couldn't get it to work) or pdanet (i did get this work). you connect to the pc, select charge only and make sure you have usb debugging turned on.
when you connect via teh usb tether option, it shuts down 4g and 3g. sucks.
so, pdanet still works? thats awesome, i just connected this yesterday and was wondering if it still worked after froyo. i cant wait to get home and try it!
pda net worked, but was relatively slow. (full bar 3G)
If I can I will go to my 4G(3bar) area, and try it again during lunch, and give results.
They indeed locked it down, as they should.
Anyone else have Froyo speed reports with PDAnet?
i was pulling 1.3-1.4 download speeds last night. not good at all. on 2.1 with internet sharing, i was pulling 4+ on a regular basis.
the network in general seemed slow last night. seems faster today. i did pull 9.11 megs down on teh evo, but not tethered. will report back tonight with updated pdanet speeds
PdaNet does work. Somewhat slower using SpeedTest.net on the Computer than using it on the EVO. But again, the good news is that it works. Maybe Easy Tether will be able to come up with a Fix.
The 4G was unbelievably slow in Houston, Tx in areas, until the day before the 2.2 Update. I have been working on this with Premier Care, AND Upper Technical Support for about 5 weeks.
I ran them a little bit ago. I wish I would have done a screen capture. Maybe later.
4G with PDA Net on Computer running around 6.3 MB/S download now.
4G on EVO running around 8.3 now.
I hope this helps.
P.S.- Until the day before the upgrade, it ran around 2.5 MB/s on EVO. This was max. It started around 700 KB/S 5 weeks ago and steadily rose over time.
Other than argument, what do you base this quote on?
Why even bother having it in there, and stating they were changing it from Internet Sharing to USB Tethering? Why state that if they were going to lock it down except for paying the $30/mo. And why would they want to have Verizon have it open and not Sprint. Not unless Verizon has disabled it also.
I can kinda see why they would want to charge $30 for an 8 Hub Hotspot. USB Tethering would be almost usless to advertise if they are going to charge $30/mo for that also.
I am using easytether via my phone (turned off wireless on computer) to send this message on my computer. Do not set your phone to USB tether. Just set it to disk drive. But it works fine.
pwnst*r - I do not agree, USB tethering had nothing to do with the services of the phone, they should NOT lock it down. The more they lock down, the more apple-like they become. They offer a wireless tether for several devices. THAT should be locked down. Wired tether should not. Period.
Oh I may need to add that I'm on .3 and not .6 though. If they have locked it down in .6 all the better that I'm on .3. I'd be ticked without my usb tether.
No it's not. Using their app you should expect to pay for the service as they clearly state ahead of time. There are software alternatives.
From a sprint persepctive it might make sense to lock it down (get more hot spot sign ups), from a consumer perspective, it sucks that they locked it down. (gotta pay for hot spot or a thrid party app)
so yes, it's debatable depending on if you are sprint or the consumer.
so at the end of the day, they have cost me and a number of other people 10-20 bucks and they haven't helped their bottom line, at least not from us. I'm sure some people will sign up for the hot spot now.
I can understand that point of view as well.
Comon, we all know it will get rooted and people will still be running hotspot as they already are. And I mean the full hotspot, not just wired tethering. They people they are getting money from are the same people they would have been getting money from anyways. People that have to have it and don't care what their phone bill is.
i just went to the verizon site and priced out a incredible and its 20.00 bux for the hotspot, so verizon charges also
For Hotspot, but how about charging. Is Verizon charging for that when the update hits? That is the question.
Verizon adjusted their ETF to over $300 (I think it's about $350 per phone)
AT&T - 1 month later AT&T adjusted theirs from $175 to $325.
about 1 month later:
AT&T put a 5GB cap on Data.
1 month later, there was a rumor that Verizon was going to do the same.
Why isn't the FCC investigating Price Fixing? Just wondering.......
