I'm following directions, but there is no notification that shows up indicating the USB and droid are connected. It's saying it's charging, but there is no notification that comes up on the phone. I am trying to install isyncr and am stuck.
once your droid is plugged in, you will see a new notification pop up in the top left of your notification bar. pull the notification bar down to open your notifications. select the one that says 'enable sd card' or something like that. (doing this from memory).
you will be asked if you want to 'mount the sd card'
tell it yes.
give a second and then you should see your droid appear on your desktop.
I'm saying my droid is plugged in but I'm NOT seeing the new notification pop up. That's the problem that I don't know how to fix. I know it can't be the cable because the phone says it's charging. There is no notification.
