The main piece of equipment you need for this to work is a USB OTG cable/adapter. You can plug most USB peripherals (like keyboard, mouse, hub, etc) without issue using this.
However, dependent on the stick, there may be limits. I think the highest I've heard is 32GB USB2.0. Anything higher or requiring USB3.0 may not work due to greater power requirements required to operate. USB external HDDs work but require an external power source. A powered USB hub may overcome these restrictions, but will be dependent on the make and power it provides.
So if I plug in a 1TB hard drive (powered) to my Note 8 via one of these OTG adapters, the tablet will read it??? For the sake of a couple of bucks to get one online, I will be trying this!
Has anyone tried USB stick to Notes micro USB to load movies or files?
Out of curiosity, is there any difference between the 64GB (which failed to be recognized) and the 128GB (which was recognized)?Just tried a brand new 128 GB Sandisk USB stick with the adaptor.
Seems to read with no problem. Will try and transfer files and movies tomorrow.
Shofar
64 GB is Kingston Data Traveler 150 - with lots on it. As I said it does work on my ThinkPad Tablet (Android).
128 GB is SanDisk Cruzer Glide - tried it brand new. Will try and move files to the Note today.
