Im having some weird issues like battery stats not resetting after a charge, the charge beep happens ocassionally for no reason and when switched off the charging screen flashes even though its not plugged in?
Blast of air would usually fix it. Occasionally there is a build up a particles on the USB tongue inside the phone which then requires some very careful cleaning with thin slivers from a toothpick and some gentle cleaning agent....of course only worth doing if you continue to get USB/charge problems.
