rapidsandroid
Is Blocking Mode not on Verizon S3's? I can't find it at all.
I read somewhere that Verizon hid the option from the menu.
What Doit2it stated above may work on some phones, but it doesn't work on my Verizon S3.
I came from blackberry (had used 5 different BB before). When I started android the single most important feature I missed in blackberry is the Auto on / off. Now this blocking function made it, only better (allow you to set exceptions). I understand there are some apps there to do something similar but coming from BB I would have expected this is a built-in feature.
I love this new feature.
My only gripe with it so far is that it leaves an icon on the status bar that I'd rather not see. I've not found a way to get rid of it as Blocking Mode doesn't seem to have the option of not displaying it.
Blackberry devices are so slow to turn on that the "off" function is actually only a standby function, making auto on / "off" appear to work so well.
My gripe with blackberry is the only true way to keep it off is to remove the battery. My bold, I could (literally) blow on the power button and it would turn on. This was poor given I needed it to be off inside my bag.
I've got rid of it. You need root though. You have to decompile settings.apk and change some code.
I use Ring Scheduler & Auto Ring ( by developer farproc )....
I use Juice Defender Ultimate to turn my smart phone into a phone and have it wake at certain times for 2 or 5 minutes to allow apps to sync. I also allow certain apps to override the JD settings.
Iveonly just swapped from an iPhone and that had 'do not disturb' feature which is the same as ' blocking mode'. The only problem I have when I've tried this mode is that it also silents your alarm clock but with the iPhone your alarm still went off
