Use Dolphin Browser HD 5.1
mburwen
This is a heads up. Dolphin just released version 5.1 of its HD browser. It is MUCH faster than previous versions of Dolphin and current versions of Chrome. For some reason it did not show up in the Update list, but I downloaded it directly from Android market and it installed over the old version and retained the add-ons and cached data as well. If you go to the Dolphin website and sign up for announcements, they will automatically email you when updates are available.
There is also an HD 6.0.0 beta which i got the APK for :)
HI!
Okay, so I'm new to this tablet and new to droid in general. I found the Dolphin Browser in the android market; however, it's telling me that it is incompatible with my superpad. What do I need to do?? Several apps have told me this, even though my pad is supposed to support Android 2.2.
Thanks!!
HI!
Thanks!!
Try running Tim's 4e ROM (see elsewhere in this forum for instructions on how to install.) If you are running the firmware that came with the device, you will have plenty of trouble.
