Use sensor aiding
What is this feature?
How does it save battery? It says "enhance positioning". Something that enhances positioning doesn't sound like it would save battery.
i have rewritten this, hopefully more clearly.
battery whore, but very accurate: gps
use wireless networks: self explanitory - ONLY cell towers are used. not as accurate as gps.
use sensor aiding (actually a passive wifi locator): even if your phone's wifi is turned off, even if your gps is turned off, if you walk or drive by a starbucks, your phone still passively "picks up" wifi signals" and the wireless network towers better know your exact street address. if your gps is turned on, this helps reduce the stress and power used by the gps pulse to find you. sensor aiding will definitely save battery. sensor aiding also helps wireless networks/towers to find you more accurately. most restaurants, coffee houses, retail stores, shopping centers, etc., etc. have free wifi today.
in my opinion, sensor aiding will always help save battery by using wifi hotspots to send your EXACT street address. sensor aiding will not help on a road trip in the middle of nevada or montana. think of sensor aiding as a passive wifi locator without you turning on your wifi in a city. so, yes, sensor aiding will ALWAYS save battery.
in the middle of nowhere, gps will work better if you also have wireless networks turned on to better find you.
in a city, i would use wireless networks and sensor aiding, period. cities have plenty of network towers, so in a city, gps is not really needed.
does this better explain it? if not, turn on google maps, and walk around your block and experiment using the different settings to see what you think. just remember, gps is a battery whore!!
It's interesting that the sensor aiding option becomes grayed out after disabling GPS, makes me think you can't use sensor w/o GPS.
i have not used this setting yet, and i gave bad info, sorry. i did not know that. i "assumed" it worked with both gps and wireless/tower settings. well, i would recommend then to just use the wireless/tower setting to save your battery unless you are in a car and have your phone charging at the same time.
The samsung website says this..
Sensors enhance pedestrian positioning and save battery power. When indoors or underground, sensors work best if handset is aligned with the direction of movement. Distorted magnetic fields will affect performance
What do distorted magnetic fields have to do with it?
Sensor aiding is used when there's no GPS signal. This is not new, most old Tomtom devices have it.
For example you enter a tunnel. The GPS signal is gone. The phone will then rely on the sensors to calculate your speed and direction to extrapolate where you are. It works but only for a while, afterwards the margin of errors becomes too great and a GPS fix is needed.
