This is by no means a definitive list, it's just a list of apps I've either found useful in the time I've had my handset or I've seen come up a few times on this forum. If there's an app you don't see here and you think it deserves a place, drop me a PM and I'll see about getting it added. Incidentally, this post will be quite lengthy, if anyone wants a more compact version, let me know and I'll trim it down a bit.
I've linked to some paid apps here, most of which have a free alternative.
My first recommendations is.....
DO NOT INSTALL A TASK KILLER
There we go.
If you take nothing else from this thread and just heed the above, then this has been worth it.
Seriously, to a certain extent, they weren't needed on Eclair (2.1) and they were definitely not needed in Froyo (2.2). Given the Desire HD ships with Froyo, I'll let you do the math. Android is designed to be its own task killer, just let it do its job, it is pretty good at it. Just because you see an app held in RAM, that doesn't mean it's taking up battery. I hear things like "I use it to free RAM to make my phone faster/make XXX run better". If Android needs more RAM, it'll free it of its own accord as and when required. If you notice your phone acting sluggish, reboot. If it's consistent, check what's taking up CPU usage and if it's an
app you've installed, uninstall. If it's one of the stock apps, post here, I'm sure someone will be able to help.
If you want more info on why Task killers are not required, you can look here. If you want a more technical overview of how Android manages tasks, take a look at what google have to say about the matter, here.
Phew.
There we go.
Phew.
