Maybe if you include your general location, someone from nearby that has messed with that can give you an idea. Otherwise what works for one may do nothing for others.
Just wondering if anyone has found a pretty good PRL to use with the triumph.. i know that each one varies based on location. I just wanna know what everyone else uses. Ive tried about 5 or 6 of them and cant seem to find the right one..
Off-Topic, but congratulations on becoming a moderator Agentc13!
I'm in Oklahoma City. I'm still on stock, but I'm guessing the latest sprint PRL would probably be the best. Is this true?
Also, what exactly does a different PRL do? It won't all you to roam will it? Will it cause you to get the higher priority of Sprint users and not the lower priority of VM users? (This may not actually exist, but I thought I had heard of it).
Im using 60686 in LA area and on speedtest im getting 422ping 34kpbs DL and 131kbps UL with 3g at 1 bar, anyone have better results with other prl's in the LA area?
