1. Is the port on the Note3 the same as the Note2?
2. If not, is there a way to use my Note2 charger with the Note3? Maybe with an adapter? Or should I just get a new charger?
Thanks.
The base, not the cord.
What do you mean by the base, not the cord? Do I need some adapter?
No... you can use the note 2 cord or any micro USB cable sine the USB 3.0 port on the n3 is backwards compatible
^Yes
But obviously if you use the Note 2 charger, you won't be able to charge as fast as the Note 3 USB 3.0 charger.[/QUOTE
Only going to make a difference if your charging the note 3 with your computer if it also has a 3.0 usb port.
The batteries are very similar and the note 2 chargers will work just fine on the note 3.
^Yes
