1. If I get a stylus to use with a Nexus 7 will it be pressure sensitive?
2. Does it work out of the box or do you need to do anything to make it work?
3. Any specific models anyone can recommend?
Hi, My stylus also came with my case, I find it very easy to use, they are not pressure sensitive and there is no setting up to do. If you need to zoom in or out either double tap the screen with the stylus or use two fingers.
