Help Using a WiFi Direct Printer to Print from Note 3
recDNA
How do I use my note 3 to print to a wifi direct printer. Happens to be an HP 8600. WiFi direct is set up from the printer. Can I remain connected to another WiFi network and still use WiFi direct to the printer simultaneously? Thanks for your help.
I have the HP7510 and it works fine on one wifi connection. The printer is configured to the same network and it all works as it should.
