I found these instructions on xda (
[APP] Darktremor A2SD (Apps2SD) version 2.7 Update 1 (2010-05-16) - xda-developers ) I ran the check to see if it was working and saw that it wasn't. So I ran this command as shown below ..... /system/bin/a2sd install
Once I did that it moved all my apps to my sd card and worked correctly
I did the partitioning before I installed the rom including the ext 2 to ext 3 step.
How to tell if it is working:
1. On your computer in the Android SDK Tools directory, type adb shell
2. In the adb shell, type /system/bin/a2sd check
3. Read the report. It will tell you if all is well. If you see anything with [X], type a2sd repair
If you want to move the apps to the SD card (when the program doesn't do it for you or you have moved the apps to the internal storage in the past):
1. Enter the ADB Shell by typing adb shell
2. In the ADB shell, type /system/bin/a2sd install
To prevent A2SD from running, type /system/bin/a2sd remove
