D
Deleted User
Guest
Android Version: 2.1 (Doughnut?)
Network: T-Mobile
Issue:
I'm having a little trouble connecting to my phone using adb when it is booted into fastboot (from an XP machine). Basically my phone has stopped booting correctly (it just loops infinitely between the HTC and TMobile splash screens), and I'd like to use adb to have a look around and see if I can fix the problem. If possible I'd like to avoid a factory reset.
At first when I plugged my phone into the pc via usb it popped up a 'Found New Hardware' saying it had discovered an 'Android 1.0 device', and asked me for drivers. The drivers I got from HTC Synch weren't recognised, and after a little playing around I realised the USB Bus ID listed for a HTC Desire phone in the .inf file for the drivers did not match the actual ID for my phone reported by windows. After I fixed that the drivers installed correctly and the 'Found New Hardware' box stopped popping up when I plugged my phone in.
Unfortunately adb still didn't detect my phone, and neither did HTC synch. Also, when I tried to access the SD card on the from from the generic Mass Storage device added into explorer it popped up an 'insert disk' box and wouldn't let me access it.
Has anyone else had this problem, or have any suggestions on how to fix it? Should I be able to connect to the phone using adb when it is in fastboot? I've seen several examples on the net where people claimed to have done it so I'm assuming you should be able to.
Very last resort before I give up and factory reset the phone.
If anyone's interested I posted earlier describing the infinite-loop problem here: http://androidforums.com/desire-support-troubleshooting/187583-no-space-left-device.html
Network: T-Mobile
Issue:
