if u long press the power button, a menu will pop up. Last option is "Mobile network". U can turn off data by clicking on it..
Its been my experience that, on AT&T, if you activate a smartphone, they will detect it and begin charging you for a data plan. We had this happen when my daughter swapped her GoPhone SIM into a used Blackberry.
Will MMS still work?
It will work, but the data used will be added to your bill.
I am on the $15 unlimited plan and I have been using a Samsung Jack for a year and now my Captivate. My wife has been using a Blackberry for over a year with no data plan.
AT&T enacted the forced data plan for all smartphones a year or so ago from what I read.
What $15 unlimited plan? AT&T?
It really depends. They do check occasionally but I'm not sure how often for the Aria. For phones such as iPhone and Blackberrys, they generally have a routine check or so I've heard fro ma friend.
I don't have a data plan and have never had one with my Aria and it's been going just fine for me. When you set up the phone / account, I simply went with use WiFi or so and then checked / turned off all data related things in settings and I haven't been charged for using data either.
