Apps Using ASP.Net Web Service (3.5) in Android
Hi
I am trying to connect to a web service (coded in ASp.net 3.5 Express edition) in Andoid Code, but I am getting the following error
android.os.NetworkOnMainThreadexception
when this line is executed
androidHttpTransport.call(HelloWorld_SOAP_ACTION, envelope);
1. My Web service code is as follows- which working(I tested from C# Windows application)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.Services;
namespace WebService2
/// <summary>
/// Summary description for Service1
/// </summary>
[WebService(Namespace = "http://tempuri.org/")]
[WebServiceBinding(ConformsTo = WsiProfiles.BasicProfile1_1)]
[System.ComponentModel.ToolboxItem(false)]
// To allow this Web Service to be called from script, using ASP.NET AJAX, uncomment the following line.
// [System.Web.Script.Services.ScriptService]
public class Service1 : System.Web.Services.WebService
[WebMethod]
public string HelloWorld()
return "Hello World,hhh";
2. My Android Code is as follows
package com.example.wstest;
import android.os.*;
import android.app.*;
import android.view.*;
import android.view.View.OnClickListener;
import android.widget.*;
import android.content.Intent;
import android.graphics.Typeface;
import android.text.SpannableString;
import android.text.style.StyleSpan;
import android.view.ViewGroup.LayoutParams;
import org.ksoap2.SoapEnvelope;
import org.ksoap2.serialization.SoapObject;
import org.ksoap2.serialization.SoapSerializationEnvelope;
import org.ksoap2.transport.HttpTransportSE;
public class MainActivity extends Activity {
private ProgressDialog pd;
private Thread SearchTread;
private static final String NAMESPACE="http://tempuri.org/";
private static final String URL ="http://localhost:1852/Service1.asmx"; //Web Service URL
private static final String HelloWorld_SOAP_ACTION ="http://tempuri.org/HelloWorld"; //specifies the action
private static final String METHOD_NAME1 ="HelloWorld"; //specify the method name what u r calling
@Override
setContentView(R.layout.activity_main);
final Button btnDlg = (Button) findViewById(R.id.btnDlg);
btnDlg.setOnClickListener(new OnClickListener() {
@Override
public void onClick(View v) {
StartThread();
protected void StartThread()
//show process dialog
//pd = ProgressDialog.show(this, "Job Searching", "Contacting Web Service, Please Wait...");
SearchTread = new Thread() {
@Override
public void run() {
handler.sendEmptyMessage(0);
SearchTread.start();
private Handler handler = new Handler()
public void handleMessage(Message msg)
//this is the function that do the search
DoSearch();
protected void DoSearch()
SoapObject request = new SoapObject(NAMESPACE, METHOD_NAME1);
//request.addProperty("methodName","HelloWorld");
//create soap client
SoapSerializationEnvelope envelope =new SoapSerializationEnvelope(SoapEnvelope.VER11);
envelope.dotNet = true;
envelope.setOutputSoapObject(request);
HttpTransportSE androidHttpTransport = new HttpTransportSE(URL);
//call the web method from the URL
try
//android.os.NetworkOnMainThreadexception occurs
//get the response as raw;
SoapObject objs = (SoapObject)envelope.getResponse();
Toast.makeText(MainActivity.this , "DoSearch..objs", Toast.LENGTH_LONG).show();
catch(Exception ex)
Toast.makeText(MainActivity.this , ex.toString(), Toast.LENGTH_LONG).show();
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.activity_main, menu);
return true;
This could be because of StrictMode mechanism. StrictMode is most commonly used to catch accidental disk or network access on the application's main thread, where UI operations are received and animations take place.
You can read more about this here. If you necessarily needs to do that(this is not a good practice), put this code in the onCreate() of your main activity before setting the layout.
public void onCreate(Bundle savedInstanceState) {
// permits to make a HttpURLConnection
if (android.os.Build.VERSION.SDK_INT > 9) {
StrictMode.ThreadPolicy policy = new StrictMode.ThreadPolicy.Builder().permitAll().build();
StrictMode.setThreadPolicy(policy);
