using bluetooth and headphones at the same time
JereNet
Does anybody know if it's possible to use either a Bluetooth headset and headphones or 2 Bluetooth headset at the same time on a Droid incredible 2 for like listening to music etc.
yes. I used a scala teamset pro headset on my helmet when riding my motorcycle, and i can listen music, radio, gps, etc. while using the plug in headset, and the bluetooth portion will come through and take calls and pause the music while on the phone.
I mean is there a way that I'm able to use both the headset and Bluetooth headphones to listen to music, such as me listening via Bluetooth and a friend using the headset at the same time?
oh sorry for the confusion lol... i dont even think our phone does bluetooth music, or i dont know how to anyway, but i think radio shack sells y shaped adapters for two pairs of headphones, if those even exist.
Yes, DINC2 puts music up on two different BT headsets I own, Blue Ant Q2 and Sena SMH-10 (motorcycle helmet headset). However, audio goes either to the BT or the jacked in phones, but not both. If the BT headset is connected, the phone jack goes quiet.
Vehicle just came out with some slick looking headphones with a Mic. Assuming the fidelity is reasonable I am gonna snag a pair. Google music just keeps kicking out the jams.
Be aware that the fidelity can blow over BT, so if that is important to you wired is your friend.
you can't use multiple bluetooth headsets at the same time(or normal headsets), but if you use this tool: bluemusic ..this will list all the bluetooth devices in range, including carkits and you can easily switch between them .
