Using desire on first charge?
1
12078215
Guest
Is there any problem doing this? I know I should probably wait till tomorrow but I cant wait to get my hands on it!
I had the same problem this morning! Due to all the battery life talk on here I decided to be cautious and let it fully charge before turning it on. I doubt it will make any difference but you never know. Mine took around 2 hours to charge so it's not that long to wait.
The only problem you will find is the battery life on the first couple of charges (don't panic though, it get much much better).
Combine that with the fact you will probably want to play with it a lot and try everything out it won't last long.
