Can someone please tell me how to take Twitter off of the Friend Stream? I use the Twitter widget for that service and like to use Friend Stream for Facebook only.
if you have the friend stream on its own page, tap on the arrow icon top right,
hit the menu button soft key at the bottom, then settings,
accounts & sync
uncheck or disable whatever social site you dont want to use. this should take you to the "Data and synchronization" screen.
i think, though, if you do that you also will disable that network from running globally..meaning if its disabled there it wont run in any other app.
friendstream is meant to have all of your sites you are logged into running on that page.
from htc:
How do I use Friend Stream? close
You can use Friend Stream to interact with friends across multiple social networks like Facebook, Twitter, and Flickr
Well that sucks. It's so cluttered looking at everything all at once on one widget. I like Sense for the interface and widgets themselves. That's why I haven't rooted and went to MIUI yet. I have Executive Assistant, but feel like that defeats the purpose of using Sense and takes away from the uniformity it has. I like the scrollable widget over the half screen one.
