create the following folders in the root directory of your SD Card
ringtones
alarms
notifications
I am all new to the hero and i would like to know how i create the above folders, and i am having trouble to see how i can down load music to make into ringtones.
thanks
thanks
Plug your Hero into a PC via the USB connector, mount the Hero by via Notifications and you'll be able to view the SD card on your PC. Create the folders on the SD card (not in any of the folders) and copy mp3's into the folders to be able to use them.
Chegs.
thanks for the info, however, i cant see how i view hte SD card on my PC or how i would be able to creast the folders on the SD card. All that happens is i press mount and brings up a pop up thing on my screen with different options including , play using windows media player, copy pictures. Not sure what i should be doing from this point
