Using Nokia Charger
vkthor
Hi folks!
Just got my Note thanks to Vodafone Spain. It came with a USB charger which is 5V 1A. Question is, I already have an USB charger (same plug) from my old Nokia phone (the mighty N900), but it's 5V 1.2A.
My question is, will there be any problem if I charge my phone with this charger? Should it charge faster?
Thank you! :)
I have the exact same story. I use my Nokia charger all the time (since I leave the Samsung charger at work) successfully. I even bought a couple of extra Nokia chargers to have about the house since other power bricks that I bought had some bizarre effects on the phone. I cannot say that it charges any faster but I can tell you that it works just fine. I always thought that it was the device that dictated how much power was drawn from the charger in any case.
