Using other's Nandroid
Is it possible to use someone else's nandroid backup and vice versa? I don't have any experience on this matter.
Hmm interesting question, i would think as long as its the same phone, it may work, but really not sure, never tryed it lol.......;)
Yes it's possible like doc said as long as is from the same phone you're good to go. I have done it. All I do is remove md5 checksum, delete both files from the backup and that's it restore.
Note:
You will have to modify the nandroid to not include data and cache. Other wise you will be sharing your information as well. Or just restore everything but data and cache. You can do that by advance restore.
One thing to keep in mind, it has to be restored on the same kernel as the backup was made on, or the md5sum will error out...
Edit: Well it was mentioned that you can delete the md5sum, I have never tried that.
