Root Using phone storage
So... now that we have root. Is there a way to force particular applications to use the built in 8GB of phone storage? For example, doubletwist automatically syncs to the SD card, ROM Manager saves backups to the SD Card, etc...
I find that I have used basically none of my internal memory because nothing recognizes its there in the first place. Is there a custom ROM that allows this? I know it is supposed to be a feature of Froyo, but it seems kind of silly that it doesn't already work or that there wouldn't be a root method to make it work.
