Help Using song as text message notification
Download the app "ringdroid." Clip the portion you want and save it as a notification tone. Go to your text app and change the notification ringtone.
on your sd card...
create a directory called "notifications"
save all song clips you want to use in there.
android will auto find them for your needs
same for "ringtones"
do u know how to connect the usb to your pc?
then choose "connect as drive".
use as a normal flash drive.
Oh my gosh that app is amazing thanks it works perfectly and its is really easy and the relly big plus is that it is free.
