Help Using the tab without a SIM card
skittleys
My Mom got a Tab for Christmas, and she's having a lot of probs with it! She doesn't want a data plan, so there's no SIM card in it, and this is causing numerous problems.
For example, when using the "Reader's Hub" app, when you click update, it says "Error: No SIM. Unable to launch application.". There seems to be no way to bypass this!
I read here that you can select to use it without the SIM on the first boot: Will the Galaxy Tab work without a SIM? - Android Forums. Is the only option now to do a factory reset?
How do we make this thing work?!
So long as you have Wifi access then you should be able to go Menu>Settings>Wireless and network>Mobile networks then make sure that "Use packet data is UNticked.
yep tried that with my vodafone sim, but didnt seem to want to go fully in, which way up should it go, chip facing down or up
Try this.
If you managed to get your hands on a Samsung Galaxy Tab without a data package, here is a short trick that shows you how to bypass the activation on the android tablet in order to freely use it in Wi-Fi mode only.
  • Press
