Root using unrevoked
YamiR6
Member
I did everything they said. once i click on unrevoked the screen just shows pushing unrevoked forever....(223304 bytes) and just sits there doesnt do anything at all. last time i remembered doing this it was a lot faster and i did more things to the phone. What happened to cause it to do this? Can someone please help so I can root the phone. This is a brand new phone just activated it yesterday.
shawn
Current release of unrevoked doesn't work with hboot 2. There's another method u can use to root. If u do a search u should find a few posts on it.
Thank you. I am on T1 right now so it will take me 40 minutes to d/l that hboot so I'll have to do it at home.
You should not try that method unless you know what you're doing. You're much more likely to brick your phone. Unrevoked should have an updated version soon.
