Help Using uot kitchen with cm7
starstress
Has anyone done so? If so can you tell me what files to upload, I tried the cyanbread but I get nothing, havent tried androidian yet but dont wanna go through putting it together only for it not to work, rather know for sure
Yeah, I also tried uploading one of the themes and customizing it but when I rebooted it would go back to stock so I decided to change the default theme like in any other rom. Just upload what it tells you to: SystemUI.apk (can be found in system/apps) and framework.apk (found in framework folder.) Hope this helps. I still have the theme I made if you would like to try it. It is a black and red theme.
do this make your theme in the kitchen when you get to the file upload part choose a cm7 theme chooser apk like Cyanbread.apk or Androidian.apk when it's done cooking it will give you a zip file open it and get the new apk file place on sd card navigate to it using a file manager install it then go to the cm7 theme chooser and apply it then reboot phone.
That was my problem, every time I rebooted it would revert back to default. Is there a workaround for this or something I missed. I no longer use CM7 but it would be go to know if/when I go back to using it. TIA
i used the windows phone theme apk and it works even after rebooting
Uploaded with ImageShack.us
you can use any theme chooser apk that works on your phone the icons will remain the same but you can change the status bar icons and notification pull down colors.
Im gonna try the theme chooser option, framework and system ui worked great except I kept getting a process error on the status bar.
