sabrewings
Android Expert
I used to keep my SSID broadcast at home disable, and four computers have never had a problem using the network. Only my Incredible doesn't seem to be able to reconnect to a remembered network not broadcasting its SSID. In fact, if I turn off the SSID while the Incredible is connected, it instantly drops the WIFI connection.
Anyone have luck having the Incredible use a network without the SSID being broadcast constantly? I'm using WPA2 if that makes a difference.
