I found out about it from there but it doesn't really go into detail about it. I wanna know what settings are recommended for the Ascend? (Agressive, balanced, multi-tasking) Has anybody used the script on their Ascend?
Also,if you have DT'S A2SD installed or a later version of CM7 (which has A2SD pre-installed), use the app A2SDGUI to tweak the memory settings to see what works best for you.
