Lanman1978
If you want to make the most out of your Triumph phone then I suggest running the V6 Supercharger utility. You have to be comfortable with running scripts, but I got SManager from the Google store which made it much easier. There is so much that this utility does that I can't explain it all here. Put it this way it makes your phone way faster if the script is run correctly. Just Google search for V6 Supercharger. I ran the startup kit as well. Give it a shot and don't be a wuss.
Just be sure to follow the instructions carefully and all should be well.
